2001 Ford Escape
174,000 MILES • 4 CYL • 2WD • MANUAL
SMERCER
the acessory belt was broken and replaced it was also retimed and a egr replaced the car has no power willhardly run 50 mph wide open went to autozone has check engine code system too rich note has been suppossedly timed twice i am a mechanic from old school would like some suggesstions to try and look for
Apr 3, 2010 at 2:45 PM
GETWISE
Have your DPFE sensor\Valve Pressure Sensor replaced. Very easy to do more or less plug and play.. This is a very common issue with 01 Ford Escape.
Apr 11, 2010 at 4:18 AM
