Ford EL climate control unit?
62,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
TONYAIMER
  • 13 POSTS
My ford is an Australian car
The climate control unit is working fine but usually
takes a while to come on at all and when it does it works 100%.
I have checked the circuit board for dry joints and I am
now suspecting connectors or a bad earth.
The manual for the EL falcon I have does not show the
correct wiring colours for the Fairmont model I have.
Can't find the correct wiring diagram on the inet.
Any ideas?
Feb 20, 2026 at 4:44 PM
  • 55,766 POSTS
Yep, it sounds like the blower motor is going bad which is common. Test for power at the blower motor when it is not working on both wires, if you have power to one wire, the blower motor is bad and you need a new one. This video guide will help
https://www.youtube.com/watch?v=Hlna_kUt7As
I think this is the wiring diagram for it. Check out the images (below). Please let us know what happens. Ken
Feb 21, 2026 at 9:51 AM
TONYAIMER
  • 13 POSTS
I have got the glove box out of my EL falcon fairmont but I still cannot find the blower
motor. It appears some more trim needs to come off first and I would appreciate some
specific guidelines as I could end up removing more trim then I need to.
Mar 6, 2026 at 11:26 PM
  • 55,766 POSTS
I don't have images for this car but we can find it, this car is right hand driver correct? I would use a flashlight to check under the hood and dash, upload the images here and I will help you look.
Mar 7, 2026 at 3:25 AM
TONYAIMER
  • 13 POSTS
I have 2 EL faimonts - a 97 station wagon and a 96 sedan, the latter still below 92000k
Both are RH drive models. The station wagon also has a dead climate control. The attached pics show the CCU removed again from the sedan because I previously checked for dry joints and I want to make sure I have not inadvertently shorted something out. The previous test drive was at night and everything came alive after a while. The most recent test drive was also at night and the CCU did not come alive after about 15k as before
Mar 8, 2026 at 12:56 AM
TONYAIMER
  • 13 POSTS
pic #2
Mar 8, 2026 at 12:57 AM
TONYAIMER
  • 13 POSTS
pic#4
Mar 8, 2026 at 12:58 AM
TONYAIMER
  • 13 POSTS
pic #5
Mar 8, 2026 at 12:59 AM
  • 55,766 POSTS
The blower motor it up under the dash on the passenger side, not in the middle. Also, pop the hood and look towards the firewall, ( passenger side) thank for the images it helps.
Mar 9, 2026 at 12:11 AM
TONYAIMER
  • 13 POSTS
I dont think you got 2 of the photos.
Mar 11, 2026 at 5:14 PM
TONYAIMER
  • 13 POSTS
here is the final photo. I am battling to find my around this web site.
Tony
Mar 11, 2026 at 5:23 PM
TONYAIMER
  • 13 POSTS
I seem to be sending the same piciture multiple times. I plan to remove more trim
on the LHS to try and find the blower/motor.
Mar 11, 2026 at 5:24 PM
  • 55,766 POSTS
Yep, that is a good one, did you look under the hood at the firewall?
Mar 12, 2026 at 1:50 AM
TONYAIMER
  • 13 POSTS
The blower/fan gets its air from a grill between the hood and the firewall but I will double check this when the rain stops.
Mar 12, 2026 at 3:46 AM
  • 55,766 POSTS
Yep, it might be bolts to the firewall, sorry we don't have this car in the states but we should be able to find it.
Mar 13, 2026 at 2:26 AM
TONYAIMER
  • 13 POSTS
I just thought I would bring everyone up to speed on a successful repair.
It was not the blower motor because I was able to feed 12v to it and it worked fine. I recapped the climate control board with three new electrolytic capacitors because no one expects them to last 30 years!
The intermittent problem turned out to be the +12v pin on the bigger connector which I was unable to re-pin. I did not want to make the special tool needed. I used a jumper wire through its own connector and onto the board of the ccu. Now everything works fine.
Thanks for all the ideas and suggestions which were of a great help
Today is the 19th July 2026.
Regards
Tony Aimer
Jul 19, 2026 at 5:03 AM
TONYAIMER
  • 13 POSTS
Now onto the second EL Fairmont station wagon ccu!
Jul 19, 2026 at 5:04 AM
  • 55,766 POSTS
Hi Tony,
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Jul 20, 2026 at 7:26 AM
TONYAIMER
  • 13 POSTS
I just repaired the 97 EL ford falcon station wagon climate control unit OK.
At first the blower control was not working but then I found I had left it unplugged when I checked the blower motor with a 12v gel cell.
I recapped the 3 electrolytic capacitors and re-soldered all the joints on the PC board and ccu unit to eliminate any possible dry joints.
All is working fine now on both cars.
Now I must reassemble both dashboards again!
Tony
23/08/2026
Aug 23, 2026 at 7:38 AM
  • 55,766 POSTS
Hey, nice work on the ix on that and thanks for getting back to me on that :)
Aug 23, 2026 at 9:24 AM
