Turbo replaced still no power
62,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
MRHODA2
Per dealership shop diagnostics the turbo was bad and needed to be replaced. This plus throttle body cleaning and fuel injector cleaning was $2,900.00. So I proceeded to replace myself. New turbo with associated lines (oil and water) is installed. On just a quick test drive down the block still no power from the turbo, but I could here is spin up. Before there was no sound from the old turbo. I have already replaced the bypass vale solenoid. I can certainly clean the throttle body but I find it hard to believe that could be the issue. Hoses all look good. And I have tripled checked to make sure all lines are reconnected. Looking for guidance on where to check next.
Oct 3, 2018 at 3:02 AM
Good afternoon.
Was there any codes related to this?
Did they go over basics such as filters?
I would first check the catalytic converter to see if it is clogged. That would give these results.
Did they check this?
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Oct 3, 2018 at 6:22 AM
