Will not start without starting fluid
80,000 MILES
MCGRAND
I have a fuel Issue with my E-150 5.0l. It was starting and running just fine until some days ago and then had the problem to not start without starting fluid. After I sprayed starting fluid in it will run about ten minutes again. But when I come to a stop at an Intersection the motor will take no throttle and shut off. I came to the conclusion it is either the fuel pump, fuel filter or fuel pressure regulator. The fuel filter was not changed for a long time but will be changed soon, can just a clogged fuel filter be the problem or is it probably worse than that? Also, I need to mention that the car was still standing for about four months until I was starting it again, maybe there was some rust in the tank so it clogged the fuel filter even more?
Jul 23, 2018 at 11:17 AM
CARADIODOC
  • 34,414 POSTS
You are in the right area, but I have a better suggestion to consider. The fact the engine ran okay for ten minutes suggests the fuel filter is not plugged. A plugged filter would cause the problem right away. Your description also does not sound like a failing fuel pump. The better suspect is the screen on the fuel pick-up tube in the gas tank. The contributing factor is sitting for an extended period. Mold feeds on the alcohol in ethanol, and that mold floats over to the screen when the pump is running, and plugs it. Another symptom to look for is the engine will have the biggest tendency to stall when the largest volume of fuel is being pumped, which is during coasting from highway speed.
Also consider connecting a fuel pressure gauge and hooking it under a wiper arm so you can watch what happens to fuel pressure when the problem occurs. Typically, with a plugged pick-up screen, you will see the pressure drop slowly until it gets low enough for the engine to stall.
This article might be of some help too:
Jul 23, 2018 at 1:49 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Sounds like you already answered most of your own questions! I suggest to change your filter first.There is a product called Seafoam you can buy at your local auto parts store to add to the tank to help the old gas burn better until it is out of the system. Most auto parts stores also have a tool loaner program to rent a fuel pressure tester. I would also suggest you check your vans fuel pressure to see how good the fuel pump is working. It should be between 35-45 PSI. I am attaching a link to give you an idea how. Hope this helps and feel free to ask any questions if needed. Thanks for using 2CarPros.
Danny-
Jul 23, 2018 at 1:50 PM
