2000 Ford Econoline False Neutral
HEARTLADY48
I have a 2000 Ford Econoline van with approx 72,000 miles on it...it is a 6 cylinder engine. We bought the van used in March of 2007 and it ran great until this weekend. While traveling to visit friends, driving down the interstate at about 65 mph the van stopped its forward motion and sounded as if I had accidently knocked it into neutral. I checked to be sure it was in gear and unfortunately it was. we were only about 30 miles from where we were going and the van would drive in 2nd gear so we drove very slowly and have left it there for now. It goes into reverse, 1st and 2nd without any problem but according to the mechanic when it tries to shift into 3rd or 4th it goes into a "false" neutral. He has tried to check the computer but cannot get it to, in his terms, "fireup". Can you please help me with an idea of what could be wrong or how to get the computer to come on so we can be sure of the problem? He said there was no shavings in the pan when he dropped it and the fluid is not burnt smelling. Being the van was used it didn't have an owners manual.
Jul 16, 2007 at 6:39 PM
2CARPRO JACK
  • 11,533 POSTS
If the computer wont communicate with his scanner, then check all fuses first. Then will have to verify powers and grounds at the comp. If it still wont communicate then it could be bad
Jul 18, 2007 at 7:48 AM
JEFFSEIVER
Same problem , third transmission. Slips into nuetral at high speed. The C 4 trans takes 12 quarts of t-fluid. ( check you owners manual) But the wire dip stick is unreadable. You will have to have the filter and seal changened and then count the proper quarts of fluid you put in. Make sure that the trans is not leaking. Also at about 70thousand the right rear axel should be changed because of wear from the bearings. Better to do it before it costs more money. Your mechanic should have known this. Call Bob Riley in Bull Head city or take your van to him He's the Bong!! when it comes to master mechanics
Aug 5, 2007 at 6:07 PM
Suggested Repair
If the scan tool cannot communicate with the computer, check all fuses first, then verify power and ground circuits at the computer. If communication still fails, the computer may be faulty.
Conversation Summary
A 2000 Ford Econoline with about 72,000 miles lost forward drive at highway speed and would only move in reverse, 1st, and 2nd. A mechanic reported a false neutral when it tried to shift into 3rd or 4th, with clean fluid and no metal in the pan, but could not get the computer to communicate with a scanner. The expert advised checking fuses, then power and ground circuits at the computer, and considering a bad computer if communication still fails.
