Hello I have a 1997 Ford E350 Van with a 5.4 Triton V8 it was running fine when I parked it. Three months ago. Now It's running with a skip. had it checked out at Ford Dealer. No No MIL light no codes but it has a stored code of P0352 Ignition Coil B Primary/Secondary Circuit Malfunction. I spent $3000 on 8 new spark plugs, 8 new coil packs, 8 new injectors. Still same problem exist. Then I went to another Ford Dealer for a test and they said that It stumped them because that should have cleared the issue. Stiil cylinder B or #2 still fails. I swapped #1 coil pack with #2 and still same issue. It appears just to be Cylinder #2. I went home and put a noid light to all in all 8 injectors. I found that the light flashes on 7 of them, and #2 will flash for 30 seconds then go out. Is there anything else I can try? Any help would be appreciated. Thanks in Advance. :?:
Sep 11, 2007 at 7:26 AM
