I have a 1998 Ford Econoline E150. I need to replace the driver's side headlight. I got the bulb from the auto parts store to replace it. The headlight assembly is blocked by the power distribution box.
Do I need to remove the power distribution box to get to the bulb?
What is the easiest way to replace it and what exactly needs to be removed from around the headlight assembly?
Thanks!
Thanks!
Jan 25, 2007 at 9:15 AM
