front brakes sticking
BRAD3349
I have a 1994 E-150 240,000 (and going strong). My front wheels were getting very hot. A friend told me my brakes were draging. The drivers side seemed to be the worse of the two, so i replaced the caliper, brake hose and repacked the wheel bearing. I also replaced the master cylinder. I bled all the wheels and took it for a test ride and the front brakes started to stick again. felt like i was pulling a cement truck. then right before i pulled in my driveway, it went away again. I dont want to replace stuff on the passengers side yet cause it didnt seem to help on the drivers side. Being that it was happening to both wheels, I really was leaning towards the mas. cyl. being the problem- but appearently not. Any ideas you might have on this would be greatly appreciated. (by the way, both wheels were hot again after the test ride)
Aug 21, 2007 at 4:00 PM
  • 75,988 POSTS
[quote:a2fb0194cb="Brad3349"]I have a 1994 E-150 240,000 (and going strong). My front wheels were getting very hot. A friend told me my brakes were draging. The drivers side seemed to be the worse of the two, so i replaced the caliper,brake hose and repacked the wheel bearing. I also replaced the master cylinder. I bled all the wheels and took it for a test ride and the front brakes still stick. Kind of even feels worse. I dont want to replace stuff on the passengers side yet cause it didnt seem to help on the drivers side. Being that it was happening to both wheels, I really was leaning towards the mas. cyl. being the problem- but appearently not. Any ideas you might have on this would be greatly appreciated.[/quote:a2fb0194cb]
ABS?
Aug 21, 2007 at 10:24 PM
