Code P0466
ALLSTARGAMER
1997 Ford E-250 4.2L V6
130,000 Miles
EVAP Emission control system vent circuit malfunction?
The pcm has determined that a malfunction exists in the electrical circuit for the vent control in the evaporative emission control system.
What does this mean?
what do I need to do to fix?
Where on earth is it located?
Sep 29, 2007 at 5:03 AM
MERLIN2021
  • 17,250 POSTS
I come up with P0446? try removing and reinstall the gas cap, or replacing it! If that fails here is the process to test the cicuit!
https://images.2carpros.com/forum/automotive_pictures/62217_P0466_copy_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_30961_mitchell_2_36.jpg
P0466 Purge Flow Sensor Circuit Performance Could be a leak in the canister or a wiring problem, Ford uses a smoke machine to test this system...about 100.00!
Sep 29, 2007 at 5:18 AM
ALLSTARGAMER
idiot zone and advance both came up with the same codes. The PCM has determined that a malfunction exists in the electrical circuit for the vent control in the evaporative emission control.
Definition
EVAP purge/vent solenoid circuit condition
Explanation
The solenoids and system wiring are monitored for opens or shorts
Probable causes
1. Purge or vent solenoids defective
2. Check connector and wiring
3. Fuel saturated vapor canister
4. Failed EVAP vent solenoid
I'm gonna see if i get get a test light now be back shortly.
Sep 29, 2007 at 6:29 AM
ALLSTARGAMER
ok from what i can get, when i use the test light i'm not getting a signal touchin red wire or hearin anything from touchin other wire
Sep 29, 2007 at 7:47 AM
ALLSTARGAMER
ok if we can get a little specific now what am i looking for, I got in my van and took the big cover off and the engine is visible to me and right in front of me is the solenoid-canister purge
Sep 29, 2007 at 10:48 AM
