2008 Ford E-Series Van Starting control circuit
27,000 MILES • V8 • 2WD • AUTOMATIC
TOMSHERWOOD
No dome lights. With key on - no instruments, no power windows, no dome lights, no radio. Will not turn engine over. Put jumper wire on solenoid - engine will turn over, but will not start because of no control power to starting circuit. Relay? Fuse?
Jun 24, 2010 at 12:56 AM
  • 75,988 POSTS
If its cranking over and will not start look for fuel and spark-do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 24, 2010 at 11:33 PM
