2007 Ford E-Series Van Turn Signals
39,559 MILES • V8 • 2WD • AUTOMATIC
JOEL KERN
I just noticed yesterday that the turn signals on my 2007 Ford E-250 super duty work van are not working. The lights, hazards and brake lights work. I took out and tested the appropiate fuse (#7) as listed in the manual. It tests ok with a voltage meter and does not appear burn out. What else should I try before taking in to a mechanic?
Oct 22, 2010 at 11:11 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check for faulty flasher module located behind left side of dash. if fuse and flasher is good than either wiring or turn signal switch is faulty.
Oct 22, 2010 at 1:03 PM
