2006 Ford E-Series Van Engine stalls
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
E_AMADOR956
  • 12 POSTS
I have a e450 that is beeing diag. vehicles stalls while driving when u come to a complete stop and turns back on. vehicle retrived dtc for cam and crank and egr valve. egr valve test was conducted and valve was replaced due to faulty valve also crank sensor and cam sensor had already been replaced.It is stated that crank and cam codes will appered if vehicle stalls out.has anyone have this issue with this vehicle. vehicle is operating normal the only thing is that everyknow and then when u come to a complete stop it stalls but turns on again not showing any signs of problem.
Nov 3, 2010 at 12:23 PM
  • 75,988 POSTS
Hie_amador956, Welcome to 2carpros and TY for the donation
Inspect and test the MAF and TPS sensors and recheck the EGR valve system
Nov 4, 2010 at 1:48 AM
E_AMADOR956
  • 12 POSTS
valve has already been recheked pass mas air flow ok and tp sensor also ok i would just like to point out this is a diesel engine problem still present
Nov 4, 2010 at 10:32 AM
  • 75,988 POSTS
Could be a low idle speed problem thats causing the governor from recovering quickly enough during deceleration to prevent the engine fron stalling. Could be a lubrication problem with the injection pump and water in the fuel causing the metering valve/plungers to stick.
Nov 5, 2010 at 6:16 AM
E_AMADOR956
  • 12 POSTS
can u explain more in detail as in what could be the cause of this problem and if u can give me details as in how to check this possible causes thank u
Nov 6, 2010 at 2:35 AM
  • 75,988 POSTS
I'm sorry this is as far I can take you-You need to bring the vehicle back where it was diagnosed-request for your refund.
Nov 6, 2010 at 3:58 AM
