2006 Ford E-Series Van Break Light won't work
80,000 MILES • V8 • 2WD • AUTOMATIC
ANTHONYLAURA19
What a the typical problems for Break Light that do not luminate???? what type of circuit problems???
Sep 22, 2009 at 10:23 AM
  • 75,988 POSTS
Find the brake switch follow the brake pedal arm till it meets the brake support bracket the switch is here-disconnect the switch connector one of them should have power if so use a jumper wire on the connector-check if the light turn on.
Sep 22, 2009 at 10:37 AM
ANTHONYLAURA19
[quote:c15407c00f="rasmataz"]Find the brake switch follow the brake pedal arm till it meets the brake support bracket the switch is here-disconnect the switch connector one of them should have power if so use a jumper wire on the connector-check if the light turn on.[/quote:c15407c00f]
Break switch checked good. but i dont know where it goes.. i need free online wiring diagram to find out where that switch goes. if you can help me out i would appriciate it. also tried jumper too.
Sep 22, 2009 at 10:42 AM
