2006 Ford E-Series Van
2006 FORD E-SERIES VAN
74,588 MILES • V8 • 2WD • AUTOMATIC
SAUL JUAREZ
gas smell in the fornt seats, no gas leaks or missfiring
Apr 30, 2010 at 4:08 AM
MATHIASO
  • 1,209 POSTS
Hello saul juarez
it was good idea to check the fuel line and I suppose you did not fine any leak.your next move is to make sure The fuel injectors do not leak: Clean or replace fuel injectors.
Wrong ignition timing could also cause that problem, or a faulty gas cap. recheck the fuel line fittings.those are more likely to leak.
May 1, 2010 at 2:17 AM
