2004 Ford E-Series Van electrical fuse or relay
JON E. MILES
Electrical problem
2004 Ford E-Series Van V8 Two Wheel Drive Automatic 40k miles
2004 Ford E-150 in great condition with 40K mi. The only problem I have had with the van is a blown cigar lighter fuse when using a battery charger. If I don't use this high amp charger everything is fine. After changing the fuse this time I now have a new problem. The cigar lighter works fine, but my instrument panel doesn't work, radio is dead, power windows are dead, dome light dead. I tested the interior fuses and found many do not have power. I then tested the power distribution box fuses and they are all good. I figure one of the relays must be the problem... any ideas ?
Feb 8, 2008 at 9:40 PM
LEGITIMATE007
  • 5,121 POSTS
what you can probably do to save you some time is to take it to autozone or your local parts place and have it scanned on the obd 2 scanner (for free). and it should narrow every thing down.
Feb 9, 2008 at 1:32 AM
JON E. MILES
I fixed it. thanks!
Feb 9, 2008 at 9:02 AM
LEGITIMATE007
  • 5,121 POSTS
good money ,,, excellent
Feb 14, 2008 at 4:31 AM
