what do I need to look for in a repair? Engine is sluggiish, missing and has loss of power. Could DPFE valve and hoses help this problem?
Oct 28, 2008 at 12:09 PM
BLACKOP555
✓Experienced Mechanic
its really a sensor not a valve.
but first of all you say you have a check engine light?
well that tells you the computer has detected something wrong with the vehicle and it will tell you what it detected this guide will help us get he code.
scan for codes and post them back here and we should have no problem finding out whats wrong.
Oct 28, 2008 at 2:01 PM
DAJUSTINATOR
MEMBER
1 POST
my engine light is off. but i still failed inspection because it still has codes for an o2 sensor and some manufactures part. and i was wondering if thats is what is wrong or would it be some thing with the computer in the van because the light is not on its off
Jul 28, 2020 at 3:35 AM
(Merged)
MADMIKE1735
first thing, have the van scanned for codes, find out which o2 sensor is bad.... have it replaced.... normally that will set a check engine light, so verify that someone did not unplug your bulb that shows your check engine light in the dash... alot of shady used car dealerships do that.... but the OBD 2 diagnostic port never lies.... like i said, have it scanned, replace whatever o2 its stating, clear the codes, go from there.
(Merged)
OMAX
MEMBER
i just bought a used 2001 econoline conversion van today drove it only 65 miles before the check engine light came on it seems to be running fine what could the problem be
Jul 28, 2020 at 3:36 AM
(Merged)
MASTERTECHTIM
bring it to your parts store(autozone) they will scan the computer and give you a code. check back in with us and we will tell you what to do. id get the codes before i brang it back to the place you bought it.
(Merged)
TRACIEBB
MEMBER
1 POST
Service engine soon light flashing on, running a little funny . what could be the cause.
(Merged)
OBXAUTOMEDIC
[quote:0af5d410c3="traciebb"]Engine Mechanical problem
2001 Ford E-Series Van 6 cyl Two Wheel Drive Automatic 126000 miles
Service engine soon light flashing on, running a little funny . what could be the cause.[/quote:0af5d410c3]
Could be any number of things..... Go by your local auto zone and ask them to pull code for you, they will do it free.
Post the codes here....
(Merged)
JAUREGUIPEDRO1
MEMBER
I just bought the vehicle listed above e350 Econoline van and I have a check engine light. I used a scanner and code p151 ,p131,p141 came up all of them are my O2 sensors. I replaced all of them with Bosh O2 sensors and cleared the codes then I drove 36 miles the check engine light didn't come on, but when I parked in my driveway and turn the van off then on again the check engine light came on again.
Jul 28, 2020 at 3:37 AM
(Merged)
Did the light stay on with the engine running? Also, have you checked for trouble codes again?
(Merged)
JAUREGUIPEDRO1
MEMBER
No, the light was off all the 36 miles I drove. I turned the van off then when I turned it back on again just to make sure the check engine light wouldn't come on again. it came on.
(Merged)
Okay, I asked because it should come on until the engine is running. Have you had the chance to check for codes? Is this a natural gas vehicle because the 141 indicates that it is The codes you indicated seem to be related to a short.
Let me know if the same ones come back. Also, check connectors, damaged wiring, or corrosion in the plugs.
(Merged)
JAUREGUIPEDRO1
MEMBER
I will check. thank you.
(Merged)
You are very welcome. Let me know what you find and what the codes are. One more thing. If your scanner can provide live data, let me know what the short term fuel trims are.
(Merged)
PTARGA87
MEMBER
1 POST
I have a 2000 E150 van with 5.4l V-8, 40,000 miles. The vehicle has started stalling at idle. Check Engine light is NOT on.
(Merged)
Check for vacuum leaks and check the idle air control valve. IT is on the throttle body. When removed, there is a pintil that moves. Turn the key off and on to make sure it is working.
(Merged)
WRENCHTECH
First eliminate all vacuum or air leaks in the system as suggested. You may have a bad IAC ( idle air control) but try cleaning the throttle body first. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle. If it still has a problem, replace the IAC.
