2003 Ford E-Series Van miss
17,000 MILES • 6 CYL • 2WD • AUTOMATIC
BMWFENCE
have a miss have installed new wires,plugs, cold pack
engine compression is good , fuel pressure is good ,coverter has been checked and is good ,but still have miss when you put in gear
Jul 15, 2008 at 2:06 AM
MERLIN2021
  • 17,250 POSTS
Is the check engine light on? If yes get them read at Autozone, if it show a miss on one cylinder, check the coil and injector for that cylinder, if it's P0300 you may have a vacuum leak. Post the codes when you get em!
Jul 15, 2008 at 2:19 AM
