2002 Ford E-Series Van Transmission
111,000 MILES • V8 • 2WD • AUTOMATIC
PHILIP4MIAMI
We have a 2002 E-150 Traveler 7-passenger van. Something is happening with the transmission. It usually happens at approximately 42 mph. It seems to slip or chug. It may have something to do with locking up.
Oct 26, 2009 at 1:15 PM
SERVICE WRITER
  • 9,123 POSTS
Might be a shift solenoid.
Check the computer for any transmission codes.
How often has the fluid and filter been changed?
Oct 27, 2009 at 12:34 AM
PHILIP4MIAMI
The transmission was rebuilt by a Ford Dealer in January of 2008. Not sure if the fluid has been changed since then.
Oct 27, 2009 at 1:25 PM
SERVICE WRITER
  • 9,123 POSTS
Okay, the fluid and filter should be fine. But you should check the level.
You need to see if any transmission codes have been stored. This may be a case of the being driven with a scanner to see what is happening in the data stream.
Possible shift solenoid, converter other performance ralated problem?
Oct 27, 2009 at 10:13 PM
