2001 Ford E-Series Van Trans stalls
65,000 MILES • V8 • 2WD • AUTOMATIC
FORDE-350
You can put in reverse backs up has torque doesn't slip. Put in drive strart reving engine, at about 3/4 throddle trans kicks in squeals tires doesn't slip, will shift , will go 70 no prblem, when you let off the gas it is like in nuetral till you rev it up and it kicks in again.
Mar 29, 2010 at 9:33 AM
  • 110,251 POSTS
If reverse works normally, it sounds like there is a problem within the valve body. The clutch pack that drives reverse also drives 1st gear. Have you tried flushing the system or any additives?
May 3, 2010 at 2:22 PM
