2000 Ford E-Series Van Sliding door
52,000 MILES • V8 • 2WD • AUTOMATIC
W.SCHERER
How do I remove the plastic trim panels inside the sliding side door?
Jan 23, 2009 at 7:11 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
Door panels and trim are usually held in with a couple of hidden screws and a lot of inner plastic clips. Remove all screws (if any) and then carefully pull the trim outwards. Once removed, disconnect any electrical connectors behind panel or trim before setting trim/panel aside.
Thanks for using 2CarPros.com!
Jan 24, 2009 at 9:57 AM
