2000 Ford E-Series Van oil pressure
2000 FORD E-SERIES VAN
204,000 MILES • 6 CYL • 2WD • AUTOMATIC
ONEI3RD
  • 5 POSTS
I have a ford e- 150 when ever its started on a cold morning it knocks and the oil pressure doesnt register on the gauge until the warms for a minuets im assuming a worn oil pressure pump, or could be something less costly?
Nov 24, 2008 at 7:07 AM
To find out if its the oil pump you need to check the oil pressure with a mechanical gauge. A defective oil pressure sending unit will not cause the engine to knock-
Nov 24, 2008 at 7:18 AM
