2000 Ford E-Series Van NO POWER UP HILL
162,000 MILES • V8 • 2WD • AUTOMATIC
ROCKTOFF
MY VAN LOOSES POWER UP HILL, PUT IN A NEW FUEL PUMP AND FUEL FILTER, PEOPLE SAY IT CAN BE A TRANS? PLEASE HELP, THANK YOU
Oct 19, 2010 at 9:56 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Oct 19, 2010 at 2:53 PM
