2000 Ford E-Series Van NO POWER UP HILL
ROCKTOFF
  • 2000 FORD E-SERIES VAN
  • V8
  • 162,000 MILES
MY VAN LOOSES POWER UP HILL, PUT IN A NEW FUEL PUMP AND FUEL FILTER, PEOPLE SAY IT CAN BE A TRANS? PLEASE HELP, THANK YOU
Tuesday, October 19th, 2010 AT 4:56 PM
Lack of acceleration, chugging, hesitating, jerking, bogging, misfiring etc. Could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Tuesday, October 19th, 2010 AT 9:53 PM
