1999 Ford E-Series Van Parking brake cable
JNJACKSON
How dose the brake cable hook up to the parking brake lever assembly. I had to replace the center section of cable in doing so the cable came loose frome the parking brake pedal assembly.pluse I could use a picture because it is hard to see under the dash. Thank You JNJackson
May 26, 2008 at 8:08 AM
MERLIN2021
  • 17,250 POSTS
First you should loosen the adjuster all the way, then pull the front cable all the way into the car. On the lever there is a cutout that the end of the cable fits into, then adjust the rear brakes, then the parking brake cable. Sorry no picture...
May 26, 2008 at 8:19 AM
