1999 Ford E-Series Van Leaking
154,000 MILES • V8 • 2WD • AUTOMATIC
TOBY00703
I have a Ford E150 that is leaking at the front of the motor but I can not find where the leak is coming from. The leak is green in color but not anti-freeze. The motor is not running hot but when I drive it the service engine light continues to blink and it hesitates the whole time. I have checked all the fluids except the tranmission fluids and none of them are low. Do you have any idea what it could be? I appreciate it...Thank-You.
Mar 2, 2008 at 4:26 AM
BIGO
  • 36 POSTS
its almost gotta be antifreeze if its green, if its makeing a puddle of the green fluid touch your fingertip to it then youch it to your tounge if its sweet its antifreeze.and NO a taste wont kill you or make you sick, it being sweet is why the dogs and cats are atracted to it.and ill almost gaurentee u its antifreze unless you got some new age synthetic oil thats green but it sounds like a hose, radiotor, or maybe a waterpump. you know anything about these vans abs brake systems?
Mar 2, 2008 at 2:08 PM
