1998 Ford E-Series Van pulsation
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
CTESTA
after this van warms up .from a stop while turning the rear-end pulsates only after it warms up,
from a stop on a turn while giving gas does it do this .
Aug 22, 2010 at 7:30 PM
WRENCHTECH
  • 20,758 POSTS
If you are getting what could be described as a "chatter" from the differential when turning, that would likely be cause from a limited slip differential with the clutches chattering. The cure for that would be to drain the fluid and refill it with new fluid plus a friction modifier additive that can be purchased at any auto parts store.
Aug 22, 2010 at 9:34 PM
