How to Change Spark Plugs?
135,000 MILES • V8 • 2WD • AUTOMATIC
TELMON
How to Change Spark Plugs on 5.4 v8 ford 1998 model van
May 17, 2008 at 8:30 AM
SQM
  • 6,383 POSTS
Changing the spark plugs can be done using basic hand tools.
You will first have to remove the air filter tubing and housing. Then the coils on the plugs need to be removed. After that you will have access to the spark plugs. Which can the taken out appropriate size spark plug socket with an extension.
Careful when taking out the plugs as some of these engines have a tendency to have seized spark plugs and you do not want to strip off the plug(s).
Here is a helpful video:
https://youtu.be/e68QXyBAiZo
https://www.2carpros.com/articles/how-to-change-spark-plugs
Aug 23, 2021 at 2:34 AM
