1998 Ford E-Series Van
1998 FORD E-SERIES VAN
DONNY DAVIS
Engine Mechanical problem
1998 Ford E-Series Van V8 Two Wheel Drive Automatic
I'm changing the spark plugs in my 1998 e-250 & all but one was a success. I can not get the socket onto the spark plug( I believe its #3). What are possible solutions to my problem?
Sep 5, 2010 at 9:13 PM
MADMIKE1735
  • 951 POSTS
have you tried using a 5/8" socket with a swivel and a short extension??? usually if you can get the coil off, the plug is easy.... im assuming this is a coil over plug setup....
Sep 17, 2010 at 3:37 PM
