1997 Ford E-Series Van oil in coolant
1997 FORD E-SERIES VAN
STEPHEN VAN DER LINDEN
Engine Cooling problem
Why is there oil in the coolant and coolant in the oil? This van has a V10 with a oil cooler.
May 8, 2010 at 9:10 AM
  • 110,244 POSTS
If it is the motor oil that you are refering to, you have a bad head gasket. If it is trans oil you are refering to, chances are the trans cooler in the radiator is leaking into the coolant.
May 8, 2010 at 1:23 PM
