I had a brand new engine (0 miles) installed 10 months ago, it has been driven less than 10,000 miles. The codes that came up on the failed inspection are P0401 (EGR valve) & P1537 ( no description given). I took it back to the company that installed it and they thought they might have 2 certain vacuum lines reversed.
So they switched them and at about 40 MPH the engine started shaking and the service engine light flashing for about a minute. The code came up saying that #3 cylinder was misfiring. They changed the plug and wiring and they still got the same code. They switched the vacuum lines back and it stopped. But now we have the same code again about the EGR valve and some stuck flap in the engine. Both have been checked out and they are fine. Any ideas?
Oct 27, 2008 at 1:35 PM
