1996 Ford E-Series Van no spark to distributor
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
BLUSPADER
I have replaced the rotor, cap, distributor( because the case broke while extracting one of the screws). no spark to the dist., so I replaced the coil, then the ignition module. I put new plugs n wires in a week before, so I don't know what the problem can be outside of the PCM? ECM?
any help will be appreciated
Jul 6, 2008 at 1:15 AM
MERLIN2021
  • 17,250 POSTS
Check the CCRM(Constant Control Relay Module) it has the power relay for the EEC-V system...Ignition and PCM power! Also check the crank sensor, if no signal, there will be no spark, part is 20.00 at Autozone.
Jul 6, 2008 at 2:29 AM
