1996 Ford E-Series Van ILLIMINATION
186,000 MILES • 6 CYL • 2WD • AUTOMATIC
BLUSPADER
i HAVRE NO SPARK THE THE DISTRIBUTOR, i TOOK THE CAP OFF, IT BROKE TAKING THE SCREW OUT OF THE DISTRIBUTOR. THEN i REPLACED THE COIL BECAUSE OF NO SPARK THE THE DISTRIBUTOR. sTILL NOTHING, SO i REPLACED THE IGNITION MODULE AND A RELAY THAT WAS CORRODED. i REPLACED THE CAP, ROTOR,WIRES AND PLUGS. i THINK THE ONLY OTHER THING CAN BE THE COMPUTER. tHE MOTOR CRANKS, BUT WONT START, IT HAS GAS TO THE INJECTORS, ANY HELP YOU CAN GIVE ME WILL BE GREATLY APPRECIATED
Jul 3, 2008 at 3:53 PM
MERLIN2021
  • 17,250 POSTS
First part that must be good is the crankshaft sensor (CKP) without a cracnk signal, nothing will fire! Ford CKP's cost about 20.00, worth a shot, but firt try pushing the wire onto the sensor tight!
Jul 4, 2008 at 12:52 AM
