1996 Ford E-Series Van ENGINE IDLES TOO HIGH WHEN I START I
1996 FORD E-SERIES VAN
112,000 MILES • V8 • 2WD • AUTOMATIC
QEAGLEQ2
I REPLACED ONE OF THE AIR CLEANER OUTLET TUBES AND WHEN I STARTED IT , IT IDLED VERY HIGH SO I TOOK IT AROUND THE CORNER ,I PUT IT IN GEAR AND WITHOUT GIVING IT GAS IT WAS GOING 15 MILES AND HOUR.WHEN I PUT IT IN PARK IT IDLED LIKE I WAS GIVING IT GAS . PLEASE HELP.ITS A 5.0 LITER ENGINE.
Jan 4, 2009 at 2:09 PM
  • 110,244 POSTS
Hi:
Did this problem exist prior to replacing the tube? If not, it sounds like there is an air restriction on the tube or where you have attached it. If you restrict the air, it's compensated with fuel which will cause this problem. Also, if you remove the tube, does it idle correctly?
Jan 10, 2009 at 6:50 AM
