1996 Ford E-Series Van AIR BAG LIGHT
1996 FORD E-SERIES VAN
99,000 MILES • 6 CYL • 2WD • AUTOMATIC
DANIEL2568
Air bag light blinks on and off
Jun 30, 2010 at 11:25 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Turn the ignition key to run position. The AIRBAG light will come on for a few seconds and then start the flashing sequence. Count the number of flashes. The light will flash a 2 digit number (eg. 12, or 23, or...). So a code 23, for example, will flash twice pause for a couple of seconds and then flash three times... pause for a couple seconds and repeat that sequence all over again. let me know what code you get and I can help you a bit further.
Jun 30, 2010 at 1:45 PM
