HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
E-Series Van
Engine
Symptoms
Idle High
SPONSORED LINKS
1995 Ford E-Series Van Very high idol
WAST3D
MEMBER
1995 FORD E-SERIES VAN
V8
2WD
AUTOMATIC
18,000 MILES
My idol is very high while driving and in nuetral. I cant find a vaccum leak. When I drive on the highway it seems it wont shift in to a high gear.
Any ideas?
Tuesday, January 29th, 2008 AT 8:55 PM
BMRFIXIT
MECHANIC
Check the throttle body and its link
SPONSORED LINKS
Tuesday, January 29th, 2008 AT 9:09 PM
Please
login
or
register
to post a reply.
Related Engine Idle High Content
1996 Ford E-series Van High Idle
Engine Performance Problem 1996 Ford E-series Van V8 Two Wheel Drive Automatic Came Up With A Tps Dtc, Put A New Tps In And Still...
Asked by
country0966
1996
FORD E-SERIES VAN
Multiple Misfire High Idle
When Hooke To Scanner It Is Giving Codes For Cylinders 1, 6, 9 Misfire And Egr Insuffencent However Under The Datastream All The Cylinders...
Asked by
daaron
1999
FORD E-SERIES VAN
Have High Co2 Emissions When Tested In High Idle What...
Have High Co2 Emissions When Tested In Hjgh Idle Whats Wrong
Asked by
maniacman116
1 ANSWER
1990
FORD E-SERIES VAN
Engine Started To Idling High
The Engine Idles Very Hard In Park But In Drive It Stalls, Pop, And Then Cuts Off What Could Cause This Problem
Asked by
Antonio Jenkins
1 ANSWER
1993
FORD E-SERIES VAN
2000 Ford E-series Van High Rpm At Idle
Performed Light Overhaul And Replaced Seals And Re Installed In Vehicle. Everything Checks Ok But Very High Idle Speed (about 1700rpm)....
Asked by
mpreuss1
2000
FORD E-SERIES VAN
VIEW MORE
SPONSORED LINKS
Vacuum Leak Test and Repair
Vacuum Leak
Vacuum Leak Symptoms
Online car repair manuals
