1995 Ford E-Series Van ront vents
MIKE MNMN
  • 1995 FORD E-SERIES VAN
  • V8
  • 152,000 MILES
The rear ac is blowing cool but the front isn't. Even when you put it on vent the air is warm not outside temp. Is the there a door conected to the temp control or somewhere else
Sunday, November 15th, 2009 AT 10:42 AM
MERLIN2021
  • 17,250 POSTS
Temperature blend door actuator may have broken off the arm. Or door is frozen.
Sunday, November 15th, 2009 AT 10:58 AM
PINGELITO
  • 5 POSTS
If the rear A/C is cold then that system must be working. There is a seperate door that changes heat and A/C for the front, and that door is most likely vacuum actuated. And ford designed the system to "fail" on heat so the windows would still defrost. So first thing I would look for is a vacuum leak, either under the hood near the firewall, or under the dash.
Tuesday, November 17th, 2009 AT 8:16 PM
