1995 Ford E-Series Van radiator leak
1995 FORD E-SERIES VAN
31,500 MILES • V8 • 2WD • AUTOMATIC
1SOGWAP
I have a small leak in the radiator at the top crimped ridge. I was told that a sealant could cause blockage in the channels in the engine and that I should use red pepper or black pepper as a repair. Will this work? Is it temporary? Or should I use JB weld?
Nov 30, 2009 at 2:34 AM
MICKEY-D
  • 304 POSTS
I think you should bite the bullet, and bring it to a radiator shop for a rebuild. If you like your van, and you must with all the miles on it, do it the right way, and it will go many more.
Dec 9, 2009 at 2:47 PM
WINDOZ
  • 5 POSTS
This is a byproduct of old age. I had the same problem; the seal between the plastic jacket and the aluminum core just gives way. I don't know if a radiator shop can fix this problem, as the 'old school' delt with brass radiators that were soldered and could be resoldered. Radiator addatives are a cheap and temporary fix, but flushing the system prior to replacing the radiator would be recommended. I found rockauto.com beat my local NAPA store by half for price, but you do have to wait for a week or so to get your radiator. If you have the luxury of time, it is a good option. The nice thing about your predicament is that pulling an reinstalliing a new radiator is a fairly easy fiix if you do it yourself. Good luck!!
Dec 19, 2009 at 6:49 PM
