Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
E-Series Van
Suspension
Lower Control Arm
Replace/Remove
1995 Ford E-Series Van Idle arm control valve
1995 FORD E-SERIES VAN
160 MILES • V8 • 2WD • AUTOMATIC
DOCTORTRAUTH
MEMBER
1 POST
I have replaced the idle arm control valve 3 time and it is not working..it is not opening or closeing ..how can I get it to work??????
May 3, 2010 at 3:13 AM
Experienced Mechanic
Hi:
Are you refering to the idle air control valve or the idler arm on the steering system?
As far as the IAC, is it getting vacuum?
May 3, 2010 at 6:28 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
