1995 Ford E-Series Van Air Pump Seized
RICHR22
Engine Mechanical problem
1995 Ford E-Series Van V8 Two Wheel Drive Automatic
Hi
I started up my 95 E-250 after several months and everything is OK apart from the Air Pump which is seized, meaning the belt is screeching over the pulley. Is there any way to free it up or is it a case of replacing the pump?
Thanks
Feb 2, 2010 at 5:42 AM
  • 75,988 POSTS
Its locked-up same principles as the AC compressor needs replacing
Feb 2, 2010 at 8:39 AM
