1995 Ford E-Series Van
Backround on van not necesarily related to problem. Replaced instrument cluster, IAC valve, plugs, wires, cap, and coil. The instrument cluster was the real problem causing the van to stall at stops and lights. Also the key switch is pretty ratty and sometimes when I turn the key nothing happens. Try again and it starts right up. Since all that work 12 months ago there has been a slight shutter in the 35 -45 mph range.It is hardly noticeable and has never caused me a problem. I was hoping it would get worse and maybee it has. Now the problem at hand.. I was getting on a speed ramp and the van sputterd and stalled. Started hard and ran smooth for about 20 sec and sputterd and stalled. Started hard ran smooth again and stalled. Limped it back home put it in park and it idled fine. Put it in drive and got on the gas for about 30 sec and it stalled out. Started hard but could not get it to stall out in the driveway after that. Tomorrow I will do some more poking around maybe test the fule pump. I live in the Rochester NY but today it has been 45 degrees out. No check engine light Sorry about the length...
Dec 14, 2008 at 1:46 PM
