1994 Ford E-Series Van Oil pressure
136,542 MILES • V8 • 2WD • AUTOMATIC
WPKNIGHT
The Oil Pressure guage has started to rise to the high side of NORMAL, before it never got above the O now it is running between the R and M. What could be causing the pressure to rise? The outside temp has been in 30s and 40s
Jan 22, 2008 at 4:24 AM
  • 75,988 POSTS
When the last time you had an oil change. Check the oil pressure if its normal-replace the oil pressure sending unit.
Jan 22, 2008 at 5:11 AM
