1994 Ford E-Series Van Jumping
135,000 MILES • V8 • 2WD • AUTOMATIC
DANLUV
I bought this van and have changed the spark plugs, spark plug wires, distributor cap and rotor, coil, serpentine belt, fuel filter, air filter, oil and oil filter. I have had the transmission checked by multiple shops and the transmission checks out fine, but the problem persists. when in gear it will jump or miss sporadically, then when idling it will nearlly die but rev itself back up, but when on the freeway getting above 55 it stops. can you help me?
Mar 2, 2010 at 9:54 AM
  • 110,251 POSTS
Has the check engine light come on?
May 4, 2010 at 2:37 AM
