1994 Ford E-Series Van idle
140,000 MILES • V8 • 2WD • AUTOMATIC
JEFF PUTNAM
Engine won't idle til put in park. Starts fine but when it idles down it dies unles I give it gas. When I put it in gear the idle is fine. Manual says to disconnect the battery to reset idle but that doesn't work. Thanks for any help. 5.0 engine
Dec 27, 2008 at 8:40 PM
  • 110,248 POSTS
Hi:
It sounds like a problem with the idle air control (IAC) or the throttle position sensor (TPS). First, however, I would have the computer scanned for codes. Most nationally recognized parts stores will do it for free.
Let me know if this helps.
Jan 10, 2009 at 6:53 AM
