1994 Ford E-Series Van Fuel Pump Electrical
189,000 MILES • V8 • 4WD • AUTOMATIC
BJONES5225
Engine was not getting fuel,
not starting so changed fuel pump in tank
with one from Advanced Auto aftermarket
Was problem but fuel pump lasted 2 days--
wondering if could be a electrical short that
killed first one and this one rather than just
a bad aftermarket that did not last long.
(heard a hissing noise from on top of engine a couple of minutes after turned off)
May 19, 2009 at 2:16 PM
RAVENSANCTUARY
  • 35 POSTS
make sure you don,t run the pump with out gas in the tank. That keeps the pump cool and don,t run out of gas too often check too the return tank that has the 4 hoses on it if it is clooged and there is no way to check that one it will make the pump work too hard same goes for the fuel filter clooging makes the pump weork too hard
Aug 14, 2009 at 11:12 AM
