1994 Ford E-Series Van broken bolt help
102,000 MILES • V8 • 2WD • AUTOMATIC
SERIES1957
I went to change the thermostat and broke the head of the bolt off in the housing. It is now stuck, won't budge. tryed everything including heat. What do you suggest I do now.? Its my only ride.
Dec 12, 2008 at 3:54 PM
  • 31,937 POSTS
Hi there, you will have to carefully center drill th bolt and remove it with a stud extractor, or drill and re tap the original hole, but if you try this you must take extreme caution not to drill off center.
Mark (mhpautos)
Dec 12, 2008 at 4:21 PM
