I went out to my van after work this evening and it cranked, but wouldn't start. I pumped the gas a few times (not too much) and could smell fuel. I checked the fuses and saw that 1 fuse for: air bag module, DRL module, aux. battery relay, starting system, B/U lamps, & turn lamps: was not the correct "AMP" fuse. Someone had put a 30 amp fuse where a 15 amp should be. So i changed it & the van started up. Would this have anything to do with my starting problem or is it just coincedence??
I appreciate any help.
P.S. - I should note that I think I might have a blown head gasket. I just bought the van and noticed the coolant is a muddy brown color and that it was extremely low on oil when i brought it home.
Mar 3, 2009 at 10:14 AM
