1992 Ford E-Series Van transmission swap
1992 FORD E-SERIES VAN
150,000 MILES • V8 • 2WD • AUTOMATIC
TIM MICHAELSON
I want to swap trans on this vehicle. The current trans still works but shifts like a hammer smash from 1 to 2.
I picked up a used trans from a salvage yard and they gave me the converter with it. My question. Should I switch the converter too or can I use the one in the vehicle?
Thanks,
Tim
Mar 27, 2010 at 3:56 AM
  • 110,244 POSTS
If the trans is a direct fit, you can use your converter. Just make sure the shaft where it enters the front pump is in good condition.
May 3, 2010 at 11:58 PM
