1992 Ford E-Series Van NO Signals, No Cruise, No hazard, RA
166,000 MILES • V8 • 2WD • AUTOMATIC
DKIDD100
Help! I have no turn signal power. The cruise control has no power. The RABS light is on. I suspect they're connected somehow. Brake light works. Running lights work. No power to flasher w/ or w/o hazard on, in either hot in run or hot all times. Would it be my multi-switch? can I jump power to the signals at the flasher just to get them going without other problems?
'Will be eternally grateful!!
Dan
Dec 22, 2009 at 12:31 PM
RACEFAN966
  • 5,029 POSTS
Ok lets start with fuses. In the under hood fuse/relay box check fuse N and M both 10 amp these are for the turn and hazard. Now fuse 17 in the fuse box inside under the dash drivers side. Check to see if these fuses blew. Let me know what you find and we will see what we can do from there. At some point you may need a digital multi meter.
Dec 23, 2009 at 2:09 AM
DKIDD100
[quote:df2c100407="racefan966"]Ok lets start with fuses. In the under hood fuse/relay box check fuse N and M both 10 amp these are for the turn and hazard. Now fuse 17 in the fuse box inside under the dash drivers side. Check to see if these fuses blew. Let me know what you find and we will see what we can do from there. At some point you may need a digital multi meter.[/quote:df2c100407]
Both M & N are good. One is 10, the other 5 amp. BUT!, neither has power to them, either with or w/out key on. The other small fuse next to them has no power. 17 is good with power and key on.
Dec 23, 2009 at 6:11 AM
RACEFAN966
  • 5,029 POSTS
Fuse 17 is power for you rabs module. Now I would like you to check fuse K this is what sends power to the trailer relays and then to the trailer light hookup. This is all tied together with the lighting system. Also what size Van E-150 or 250 or ? Get back to me with that and what you find.
Dec 28, 2009 at 11:29 AM
