1992 Ford E-Series Van Air Bag/SRS
1992 FORD E-SERIES VAN
71,000 MILES • V8 • 2WD • AUTOMATIC
A. T.
The SRS light on the dash blinks on 3 times in a row then 4 times in a row then repeats constantly.
Feb 6, 2009 at 3:50 AM
DAVE H
  • 13,384 POSTS
SELF-DIAGNOSTICS
The system readiness indicator light (AIR BAG warning light) is used in diagnosing malfunctions or faults in the air bag system. A fault code will be displayed when the ignition switch is in the RUN position and the diagnostic monitor detects a system fault. Certain faults may not be displayed until approximately 30 seconds after ignition switch has been turned to RUN position. This is the amount of time required for diagnostic monitor to test and verify all system faults.
AIR BAG warning light flashes a series of 2-digit fault codes. For example, a fault Code 32 will be displayed in the following manner: flash flash flash, one-second pause, flash flash, 3-second pause, then the cycle would repeat.
CODE 34 =Low Resistance In Air Bag Circuit .. all airbag repairs should be carried out by qualified tech's
Feb 9, 2009 at 1:13 PM
