1992 Ford E-Series Van
CCMA071787
  • 5 POSTS
Transmission problem
1992 Ford E-Series Van V8 Four Wheel Drive Automatic
I HAVE A FORD E150 1992 VAN AND IT ALL OF A SUDDEN ACTING LIKE IT WAS IN NEUTRAL. IT WOULD DIG DOWN LOW AND THEN GET UP TO SPEED ON THE FREEWAY. ALL OF A SUDDEN IT QUIT DRIVING. IT STAYED ON BUT WOULDNT GO. THE NEXT DAY MY DAD FILLED IT UP WITH A QUART OF TRANS FLUID AND THAT DIDNT WORK AT ALL. CAN YOU TELL ME WHAT TO DO????
Dec 11, 2008 at 5:14 PM
DAVE H
  • 13,383 POSTS
The trans is controlled by the PCM .. powertrain control module .. it's a very complex system, with sensors, solonoid's etc. you need to have the vehicles computer read for fault's at a good tran's shop ... this will tell you where the fault actually lies ?? let me know
DESCRIPTION & OPERATION
The center of the EEC-IV system is the Electronic Control Assembly (ECA). The ECA receives information from various sensors and switches. Based on information received, the ECA generates output signals to control engine and transmission operation. The EEC-IV system controls 3 major areas of engine operation: air/fuel mixture, ignition, and emission control. In addition. the system controls A/C compressor clutch operation, idle speed, and transmission solenoids. The system has self-diagnostic capabilities.
The engine control system consists of the ECA, sensors, switches, and solenoids. In order for the ECA to perform properly, it must be kept constantly informed of engine operating conditions. It is the task of the engine sensors to supply the ECA, via electrical signals, with specific information required to determine engine operating conditions. The ECA will then send out electrical signals to control air/fuel ratio, emission controls, idle speed, ignition timing, and transmission solenoids.
Dec 11, 2008 at 9:19 PM
CCMA071787
  • 5 POSTS
THANKS THAT DID HELP. I WILL LET YOU KNOW WHAT I FIND OUT.
Dec 12, 2008 at 1:25 PM
